Google+ post by Charl Cillié on 2016-04-08 10:27:43 UTC
I am unable to fix this problem. The Second layer is never quite fixed to the first. I have leveled the bed, increased temp, ect.
What is your first layer height set at in your slicer? Looks way too thick. You might want to try .3
True true. I assumed he leveled and put it at the correct height but you bring up a good point
I can set the flow rate up 50% for the first layer when I have this problem then re-calibrate the machine.
