In progress…
Look! Hardware pr0n.
Nice work.
@Kyle_Kerr you are very kind.
Look good, I like your ball screw, the pitch is very fast
@Denis_Seguin in actuator of spindle pith 20mm with servo and reducer 1:5 and 2 on Y axis bosch rexroth 5 mm pitch with servo and without reduction, i am glad you like it.
@J.P_Saini thanks, about power motor motions i thinking servo ac mitsubishi serie mrj3 (they have a awesome antivibration intelligent filters and 350 percent more power during 10 sec without overload) 400w power, inductive sensors of Fotek for limit home and limit travel and omron variator 2,2kw 3hp for Elte spindle and electronic brain i not sure… i think about Smooth Stepper or Csmio/ips
Cheers.
Great looking machine. You should consider adding weight to the base, because gantry is looking heavier than its base. İt looks like you’ll have vibration issues in the future. Keep the pictures coming
@omer_can_Inci Thanks for tip, i think about 160x80 profile strutural aluminium or 15 milimeters aluminium sheet for base… i dont know i think more time for do the right, what do you say about base?
Thanks
@Krzysztof_Foltman i didn’t make math really i improvised but in the base you… what you put in base?
