Got my laser setup today and did the first engrave.
Got my laser setup today and did the first engrave. Is there anyway to speed it up in corel draw I set it to 500mm and it’s still slow do I have something setup wrong ?
Could be your machine/device ID in the settings are not correct. Check to make sure they match your Nano board.
I think Jim 's suggestion is the solution. I had the same issue and that was the fix.
Just think of how thick the laser beam is at the correct focal point is 0.02 mm that is a lot of strokes to fill 1mm wide ,that is why engraving takes forever
