Got the belts on and I'm happy to report that it works great.
Got the belts on and I’m happy to report that it works great. There are no clearance issues and the 2:1 belt reduction is very noticeable in terms of torque output. I have no worries about adding a double direct drive extruder setup in the future. The 9 mm wide belt also helps in adding rigidity to the drive system.
The extruder mount is magnetic with alignment pins so I can easily swap between extruder setups. The belt clamp design took some time, but I’m very happy with the way it turned out. The side of the X carriage is grooved to match the pitch on the GT2 belt (a little hard to see in the pics).
Very impresive
Nicely done. I see that you use some sort of bushings instead of bearings with a washer providing the flange part. Am I seeing it wrong? If not, isn’t the rubbing of the moving belt to the washer going to affect it?
Needle bearings for idlers, 6x10x9. Mounted with a shoulder bolt, 12mm X 2mm al. spacer at top. Shims were used on top and bottom of idler assembly as well.
Mark - Yes expansion is already noticeable in the frame. When I come in to my office in the morning it is cool and I feel slight resistance in the Y bearing blocks. As my office heats up only a few degrees through the day the Y bearing blocks become easier to move. Its small amounts of friction but I can def feel it.
I knew I was going to battle design challenges using a heated chamber and I may have to redesign some things like my X rail mounts to allow some built in spring tension in the mounts. I even though about pumping water through the aluminum extrusion on the frame. They do this on some commercial CNC mills to keep the Z column height in check.
I was planning on using a heated chamber, but may not heat the chamber and just have an open top. Filaments are getting better and better and they are being engineered to not require a heated chamber.
Build volume is a little over 500mm in X and Y with 450mm in the Z.
Can I order the parts you used?
