got the missing step stick today.. made already some testruns...
got the missing step stick today…
made already some testruns… hrm
i think the glasbed is moving on the left.
i know the fan doesnt belog there…
  1. i think one “washer” is missing between the cold and hot end (wade extruder - j-head)…the head is moving back and forth.
  2. the back x-axis-rod is not horizontal…the wood broke at one point because of some nail…had to fix it…but it is not holding properly.
  3. the glas-plate/bed seems to move on the left…because the head is moving in from the left i didnt want to put something in its way.
  4. the wires which are holding the bearings are loose…need to tighten them and apply some hot glue.
    https://www.youtube.com/watch?v=VmvbSVT-Dk0
The fan doesn’t belong there? This looks like an E3D, in which case, the fan is required to be on the hot end.
Also, I see black blobs on both sides of the heaterblock. Is that leaking plastic? Did you tighten up everything?
Those noises are not good. The motor for your bed is having a very hard time.
And that nozzle is wobbling. I’m surprised you can print with that.
Tighten everything as much as you can. If needed, you can then print better-fitting parts. When I first built my i3 I had to attach my extruder with zip ties till I printed an adapter. Well, I didn’t have to, but I didn’t want to wait till I received the long M4 bolts that I was missing!
Yeah, sounds more like a loose part than the stepper. I see a loose bearing. The louder noise is related to the Y axis it looks like (front to back movement) but could still be something loose.
i think it is the copper wire that holds the glassbed that is making that noise.
Tighten when warm… If you do it when it’s cold you run a risk of problems… It doesn’t have to be printing temps but enough to soften the materal.
That’s not an E3D HotEnd. It’s a clone. I’ve not tested that particular clone but either way you really need to get a fan on that heatsink.
You might be fine/borderline for printing ABS on it, but you are at serious risk of damaging your carriage by softening it from conducted heat.
The supplier might not have provided you with a fan, but you really do absolutely need one. I don’t know if they followed the drawings for the v5 hotend accurately, but if they did you should be able to use the v5 fan duct on thingiverse and a 30x30mm fan with at least 4CFM of airflow.
