Graber i3 firmware settings
I must have missed something: When I open the “Configuration.h” from https://github.com/ErikZalm/Marlin/tree/Marlin_v1, then I can find no variables like “steps_per_mm”. Where do I have to alter these variables?
Line 389:
#define DEFAULT_AXIS_STEPS_PER_UNIT {78.7402,78.7402,200.08/3,7601.1} // default steps per unit for Ultimaker
Thanks, I got it ![]()
If you enable EEPROM_SETTINGS and EEPROM_CHITCHAT you will be able to adjust these values with M92 command without needing to recompile and re-upload the firmware.
@Miguel_Sanchez Will check that too. Thanks
At the moment I do have some promblems with uploading the firmware: https://plus.google.com/105128350515777764895/posts/ZTgMujts3QT
DEFAULT_AXIS_STEPS_PER_UNIT is what you’re looking for.
