I thought @Jim_Fong already handled this regarding the compile 4 axis for C3D Mini?
@raykholo I compiled a 4 axis version with working limits for the mini but there is a issue with G10 command. Claudio is working on a fix. Once that had been tested, the firmware will be released.
Claudio may release his version before mine…
@Jim_Fong is there any update on releasing the 4 axis version? My rotary is built and my laser is ready to go so I’m itching to try out the rotary and don’t want to go back to smoothieware if I can help it.
@Jeff_Lamb @cprezzi hasn’t fixed the zero axes issue yet. I’ll post the version I’m using now so you can use the rotary. You just need to manually zero the axes by typing in g92x0y0a0 or make a macro to do it.
download and rename to firmware.bin. Copy to sdcard to flash. Make sure you make a copy of your existing grbl-lpc settings. $$ to list them
@Jim_Fong awesome. Thanks very much. Hopefully I’ll get a chance to try it over the weekend and I’ll let you know how I get on
