Greetings, all!
I recently moved to GRBL 1.1 and started using /jpadie. I’ve encountered two issues that I’m not sure how to address.
The more minor one is that macros I create all execute twice. In fact, they save double as well (two entries of the same title every time). I saw someone posted about a similar issue in 2016, but I didn’t see any resolution to the discussion.
The more serious issue I’ve hit is a bit troublesome. I’ll load in a job (drag and drop) and run it fine. I then have a followup job (likely a continuation based on the same coordinates, so I don’t want to reset anything). I drop in that job and it renders fine in the viewer. Once I hit play on the sender, though, it begins executing the PREVIOUS job. For safety reasons, I end up letting it repeat that uselessly to avoid a loss of my zero point. I generally end up reloading ChiliPeppr entirely to get it to send the correct job after this repeat scenario. I thought I had imagined this the other day, but it’s done it to me clear as day again just now.
Thoughts?
