Greetings, I purchased a K40 laser which is assembled and functions.
Greetings, I purchased a K40 laser which is assembled and functions. Now of course I realize I have no skills on using the thing and was hoping to be able to pick up ideas for ‘get started’ type projects to build skills with the use of the machine.
I’ll be poking around here, trying to learn as much as I can. If anyone has any hot tips for a newbie, such as simple project ideas, tutorials, tasks that build confidence and skills with the machine and the software, I would be very grateful. Thanks
Corey
Waving a hand from Los Angeles, California
On my page i have some good tips https://plus.google.com/u/0/113759618124062050643/posts?cfem=1
Hello corey, I am same!! Look forward to seeing what you produce. Thanks for the link Philip :slight_smile:
I would suggest taking small pieces of whatever materials you intend to be making things out of & creating some reference “sheets”. I generally take a sheet & perform cuts/engraves of 10mm squares at various power levels & speeds to give myself a reference for future as to what is decent. Good way to get started with playing with the machine.
+Yuusuf Sallahuddin (Y.S. Creations) Brilliant Idea Yuusuf, thank you!
@Yuusuf_Sallahuddin_Y
