Grrr… just updated to fasted 3.0.1, deleted the old versions, rebooted arduino software and run the blink sketch… and then follows the longest error I’ve ever seen!
must be a simple problem! using teensy 3.0, teensy uploader is kicking in, and same result when using tty or cu (whatever they are! :: LOL ::)
any ideas?
This report would have more information with
“Show verbose output during compilation”
enabled in File > Preferences.
Arduino: 1.0.5 (Mac OS X), Board: “Teensy 3.0”
In file included from /Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi.h:50:0,
from /Users/kelvinmead/Documents/Arduino/libraries/FastLED/FastLED.h:29,
from Blink.ino:1:
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h: In static member function ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER, pSPIX>::update_ctar0(uint32_t)’:
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:121:17: error: ‘SPI_t’ was not declared in this scope
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:121:17: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:121:17: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:121:43: error: expected ‘)’ before ‘;’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:122:28: error: ‘SPI_t’ was not declared in this scope
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:122:28: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:122:28: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:124:21: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:124:21: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:126:21: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:126:21: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:127:21: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:127:21: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:129:21: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:129:21: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h: In static member function ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER, pSPIX>::update_ctar1(uint32_t)’:
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:134:17: error: ‘SPI_t’ was not declared in this scope
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:134:17: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:134:17: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:134:43: error: expected ‘)’ before ‘;’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:135:28: error: ‘SPI_t’ was not declared in this scope
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:135:28: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:135:28: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:137:21: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:137:21: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:139:21: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:139:21: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:140:21: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:140:21: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:141:21: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:141:21: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h: In member function ‘void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER, pSPIX>::init()’:
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:194:7: error: ‘SPI_t’ was not declared in this scope
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:194:13: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:194:14: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:198:5: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:198:5: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:200:20: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:200:21: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:201:17: error: ‘SIM_SCGC6_SPI1’ was not declared in this scope
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:204:5: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:204:5: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:210:3: error: ‘SPI_t’ was not declared in this scope
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:210:3: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:210:3: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:211:3: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:211:3: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h: In static member function ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER, pSPIX>::waitFully()’:
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:217:11: error: ‘SPI_t’ was not declared in this scope
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:217:11: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:217:11: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:217:33: error: expected ‘)’ before ‘;’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:218:12: error: ‘SPI_t’ was not declared in this scope
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:218:12: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:218:12: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:218:34: error: expected ‘)’ before ‘;’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:219:3: error: ‘SPI_t’ was not declared in this scope
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:219:3: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:219:3: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h: In static member function ‘static bool ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER, pSPIX>::needwait()’:
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:222:66: error: ‘SPI_t’ was not declared in this scope
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:222:66: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:222:66: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:222:83: error: expected ‘)’ before ‘;’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h: In static member function ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER, pSPIX>::wait()’:
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:223:62: error: ‘SPI_t’ was not declared in this scope
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:223:62: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:223:62: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:223:81: error: expected ‘)’ before ‘;’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h: In static member function ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER, pSPIX>::wait1()’:
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:224:63: error: ‘SPI_t’ was not declared in this scope
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:224:63: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:224:63: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:224:91: error: expected ‘)’ before ‘;’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h: In static member function ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER, pSPIX>::Write<CONT_STATE, WAIT_STATE, LAST_STATE>::writeWord(uint16_t)’:
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:241:4: error: ‘SPI_t’ was not declared in this scope
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:241:4: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:241:4: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h: In static member function ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER, pSPIX>::Write<CONT_STATE, WAIT_STATE, LAST_STATE>::writeByte(uint8_t)’:
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:249:4: error: ‘SPI_t’ was not declared in this scope
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:249:4: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:249:4: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h: In static member function ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER, pSPIX>::writeWord(uint16_t)’:
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:256:77: error: ‘SPI_t’ was not declared in this scope
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:256:77: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:256:77: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h: In static member function ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER, pSPIX>::writeWordNoWait(uint16_t)’:
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:257:75: error: ‘SPI_t’ was not declared in this scope
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:257:75: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:257:75: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h: In static member function ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER, pSPIX>::writeByte(uint8_t)’:
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:259:76: error: ‘SPI_t’ was not declared in this scope
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:259:76: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:259:76: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h: In static member function ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER, pSPIX>::writeBytePostWait(uint8_t)’:
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:260:76: error: ‘SPI_t’ was not declared in this scope
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:260:76: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:260:76: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h: In static member function ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER, pSPIX>::writeByteNoWait(uint8_t)’:
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:261:74: error: ‘SPI_t’ was not declared in this scope
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:261:74: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:261:74: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h: In static member function ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER, pSPIX>::writeWordCont(uint16_t)’:
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:263:81: error: ‘SPI_t’ was not declared in this scope
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:263:81: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:263:81: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h: In static member function ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER, pSPIX>::writeWordContNoWait(uint16_t)’:
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:264:79: error: ‘SPI_t’ was not declared in this scope
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:264:79: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:264:79: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h: In static member function ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER, pSPIX>::writeByteCont(uint8_t)’:
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:266:80: error: ‘SPI_t’ was not declared in this scope
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:266:80: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:266:80: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h: In static member function ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER, pSPIX>::writeByteContPostWait(uint8_t)’:
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:267:80: error: ‘SPI_t’ was not declared in this scope
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:267:80: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:267:80: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h: In static member function ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER, pSPIX>::writeByteContNoWait(uint8_t)’:
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:268:78: error: ‘SPI_t’ was not declared in this scope
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:268:78: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:268:78: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h: In static member function ‘static void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER, pSPIX>::writeBit(uint8_t)’:
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:272:25: error: ‘SPI_t’ was not declared in this scope
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:272:25: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:272:25: error: expected ‘)’ before ‘pSPIX’
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h: In member function ‘void ARMHardwareSPIOutput<_DATA_PIN, _CLOCK_PIN, _SPI_CLOCK_DIVIDER, pSPIX>::writePixels(PixelController<RGB_ORDER>)’:
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:351:26: error: ‘SPI_t’ was not declared in this scope
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:351:26: error: expected primary-expression before ‘)’ token
/Users/kelvinmead/Documents/Arduino/libraries/FastLED/fastspi_arm_k20.h:351:26: error: expected ‘)’ before ‘pSPIX’
