I’m a bit confused which GUI is best for use in a Raspberry/CNC setup.
Haven’t found screenshots of the WebInterface.
bCNC looks promising, but has issues? (github: vlachoudis/bCNC/issues/143)
Are you successfully using bCNC? What are the downsides?
TIA, Bernd
several users are using bcnc and are very happy with it ( just make sure you configure it correctly : http://smoothieware.org/bcnc )
you might also want to take a look at laserweb, which knows how to do cncs too.
I’m the author of Universal Gcode Sender (you can google it, I can’t post a link), CNC software which has a Smoothie option - I’m told smoothie doesn’t have a command buffer so for now you also need to enable “Single step mode” in the UGS settings (due to a GRBL-ism).
If there is enough interest, and volunteers to test, smoothie could have first class support in my app with a relatively small amount of effort. The nightly build of UGS already has a smoothie option, but I don’t have the hardware (or time) to ensure full support alone. Feel free to create issues/questions on the UGS github or drop me an email (in my github profile).
wwinder, are you still working on this? I’d love to use your platform with Smoothie. Right now I can’t get it to connect so I thought perhaps it is still be developed. I will gladly test for you. Thanks and good work!
