Guy i have a Rooky question. What is the best file format to use with the Core Draw software that comes with the machine? I’m trying to import stuff with not having much luck with pdf. Or is there better software to use? Or do I need to be hitting up the books etc?
svg, bmp, jpg, png should work better than pdf
Yeah, If they gave you the typical coreldraw 12 (very old version) it won’t handle a PDF correctly. Everything that Ariel mentioned is fine.
Or if it’s CorelDraw 12 I found that Adobe Illustrator version 9 format worked well too. Any newer AI formats wouldn’t work in CD12.
