Guys anyone know an opensource solution for doing this?
http://store.photocarver.com/en/
I’d say the logic behind making litho panels would be a good place to start as that converts contrast to depth/height map then it would be off to a Cam software to do a 3d profiling path with a heavy offset between passes… I don’t doubt all the tools need are in the open source area right now but i haven’t seen them together. I would love to see someone with more skills than my self put something together for this.
Look at Makeangelo . I’m willing to bet that code could be modified to achieve this.
GIMP (GNU Image manipulation program) has a newsprint filter that can do dot and line halftones. I’ve been experimenting with some custom software for generating line images, but using Aspire for the CAM processing.
Here’s what I would consider using. (DXF Halftone)
I’ve downloaded the software but haven’t gotten around to using it yet.
Inkscape is another free one that filters images and output dxf
@Marc_Schaefermeyer I use this program and it’s a good option and very easy to use.
I’ve played around with this software but never gone as far as to mill it on my CNC.
http://jasondorie.com/page_cnc.html
+Peter van der Walt I think tha would result in narrow dark stripes or wide light stripes or somewhere inbetween and not get you an actual difference in brightness for an area. Z offset plus intensity on the otherhand would probably work. Note that I am assuming you mean for laser work. For CNC work, a Z offset plus some translucent dark stuff would work.
+Peter van der Walt fill the groove with stain and you could do it V bit or any other bit. Just substitute Z for S and do not use variable speed control. Solid black paint filling a V bit cut and then sanding the paint off the top surface will also work.
LinuxCNC can do something similar. http://linuxcnc.org/docs/2.4/html/gui_image-to-gcode.html
DXF HALFTONE 2.1
http://www.students.tut.fi/~syvajar3/
