Guys having an issue with my Prusa i3 MK2S when i try to do
Guys having an issue with my Prusa i3 MK2S when i try to do the calibration it presses down too hard into the heat bed and i can see it physically bend when it pushes down. I stopped it immediately and im not sure what i did wrong???
Check if the PINDA probe height is corrent and check if zprobe is working by try put metal object near the probe head and use M119 gcode to check if zprobe was triggered or not.
exactly. Make sure PINDA’s light is on (on top) and put it as low as possible.
During the calibration the nozzle must not touch the bed at all.
Well i ended up lowering the nozzle until it touched the bed then placed a piece of thing cardboard under the probe and tightened the screws. That seemed to solve the issue. It started the calibration without hitting the bed but it kept failing at the 4th point.
