Guys i have a printbot simple from a friend and i need to change the printrboard. I trying to use a revF, but looks like the default marlin for this revision uses an inductive sensor on z. This printer doesnt have one and if i try to disable the autobed leveling on marlin, i get compilation errors (ConfigurationStore.cpp:73: error: ‘bed_level_probe_offset’ was not declared in this scope).
Is there an “official” revf marlin for non inductive sensor printbots???
Technically would it even make a difference if you had autoleveling enabled? I mean you just don’t put G29 in the start script in your slicer and it shouldn’t know the difference right?
@Brook_Drumm are you saying that I can’t hook up a normal mechanical endstop on the z stop port on a printrboard Rev f?? Just want to make sure before I start plugging stuff in and releasing magic smoke haha
