Guys, I know I saw this somewhere but can't find the answer.
Guys, I know I saw this somewhere but can’t find the answer. The white, or sections with no color are still being lasered in my bmp images. How do I turn that off so it only engraves the black??
What is you min power set to in the firmware and also what are you setting min power to in LW software?
It’s .3 in the firmware and I thought 0 in lw but that doesn’t mean I didn’t make a mistake. But, those are the 2 areas that would cause it? Should I have it to 0 in the firmware as well?
It’s the .3 in the firmware you are starting at 30%… 0- 0.05 should fix it
Awesome. Thank you!
@Chuck_Comito ​ did that fix it?
I updated but can’t run it tonight. Kids are sleeping but I’ll post results tomorrow.
@Alex_Krause , this was the issue and it’s been resolved. I set it there because I noticed my laser wouldn’t come on under 30 percent. I thought by doing that in the firmware I was effectively changing the scale to within a working range on the laser tube. Thank you for your help!
