Guys, im putting some order on my cave and i want to control 2
Guys, im putting some order on my cave and i want to control 2 printers from the same server. Now im using octoprint, and im creating a second instance now. I see that repetier-server supports multiple printers on the same instance, but i cannot manage to configure printers (it says that my printer config file is incomplete).
Are there any other alternatives to octoprint and repetier-server that can be run locally? (not like botqueue)
I dont have access to octoprint now but I think you can use more printers on one host. Or even instances of octoprint. Check a configuration and change port. They should run on different ports at same time without issues with different usb devices.
I check tomorrow.
