Guys, with the lastest Marlin, using a Viki LCD (havent tried with any other),
Guys, with the lastest Marlin, using a Viki LCD (havent tried with any other), when i plug a microsd card, once i start browsing the card files i cannot do “click” anymore, so, i cant select a file or go back to the main screen. The only way to recover the “click” is reseting the board.
any hints?
thanks!
I’ve been having the same issue. Haven’t had time to look into it. I figured I just grabbed a bad snapshot.
theres a few new commits, i will give it a try when i finish printing.
No luck, with the lastest marlin commits, same thing.
Whosa, im still having the same issue.
have you find a way to make it work?
Looks like a fix was merged last month. Still haven’t had time to check it out. https://github.com/ErikZalm/Marlin/pull/561
no luck. same thing and with the original pins.h i lost the encoder wheel.
iv noticed that this happens when the sd card have´s files, if its empty, it works ok. The merged fix didnt worked for me.
Update, theres a commit missing from the patch that @Whosa_whatsis referes here, Evdz will merge it tomorrow (27/9). I did test it doing the mods on ultracd.cpp and its working now, so, once the merge is done, it will work.
