Happiness is having the printer farm running full tilt..
Happiness is having the printer farm running full tilt… Excuse the rattle from the fan on the FB2020+, I’ve not got around to changing it yet. All running off a Linux machine running 5 Octoprint instances.
wow that’s a lot of printer in a room…
@Step_Cia S’only 5, plus they’re part of my business… I’m gearing up for a conversion at the moment, the Blue Migbot is being converted into an FB2020. There’s still room for a few more. There’s another FB2020 conversion then the last Migbot will be the first AX-01 that I have in the works, I’ll then add another 3 AX-01s to the farm to bring it to 8
I’m jealous
Try repetier server on the Linux box… I prefer it over octoprint and you can set users and port forward to access from anywhere. Only needs one instance to run as many printers as you have USB ports
@Abc_Def Tried it before, prefer OctoPrint. Asides, OctoPrint hardly eats any resources. The box it’s running on could probably run a fair few instances before things go wrong, the USB data flow would give out before that…
Dari printer yang ada mana yang paling cerdas dan layak untuk di beli ? berapa kira-kira refrensi harga nya ?
@Ang_HERDI nothing sub $600 in my opinion. The FB2020s are buikt and designed by myself the Migbots really aren’t worth the hassle they bring.
3d printer hevan
So you converted your Prusa i3’s clones to corexy printers. Is there a reason for that?
@Hypo_Dyne - One was a conversion, the other was a straight build. I’m converting another very soon. The reason for this is that the Migbots are OK, but not as reliable as the FB2020 CoreXYs.
