Happy Thanksgiving all! So, I’m diving into a smoothie board mks sbase 1.3 with a. Anycubic delta. I’m trying to zero it out, but its not taking gcode commands from pronterface. I have tried reinstalling the config and firmware. I CAN use the adjustment guide to mode all axis’. I cannot get the extruder to move or retract nor am I able to track temp in pronterface. When I send g28 I get a chirp from the strippers. Additionally I can open cura and run a print but it dkesnt zero home first. Any insight would be helpful
" I get a chirp from the strippers" ???
@Steve_Anken auto correct fail… Stepper motors
I’m beginning to think my end stops are incorrectly wired. I only have two wires on my end stop switches.
You might need put an invert on the endstops in the config. Send an m119 and look at the output.
So after a weekend of pretty much not touching it I got it working correctly by starting from square one. Now I need to tweek the fan settings and get the arm radius and tgermistor set correctly
