Has anyone ever used the laser to run this print, cuttingsurface.svg? I just did for first time and all seemed ok but laser would not fire and the g7 code is all new to me I have never seen this before. I recently did a cmd install of the inkscape plugin which allowed for all errors I was getting to stop. Now I am not sure what I need to do to fix this issue and again I have never seen it before now due to improper install of inkscape plugin, which recently I resolved. Here is some of the code, the plugin generated a ton of it that is certain.
G21 ; All units in mm
M80 ; Turn on Optional Peripherals Board at LMN
; Raster data will always precede vector data
; Default Cut Feedrate 300 mm per minute
; Default Move Feedrate 4000 mm per minute
; Default Laser Intensity 30 percent
G28 XY; home X and Y
M5 ;turn the laser off
;( Layer: 10 [ppm=30,feed=2500] )
;( Laser Power: 10 )
;( Feed Rate: 2500.0 )
;( Pulse Rate: 30.0 )
;(MSG,Starting layer ‘10 [ppm=30,feed=2500]’)
;Beginning of Raster Image image4556 pixel size: 753x750
M649 S10 B2 D0 R0.09406
G0 X41.053 Y98.146 F2500
G7 $1 L68 DAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
G7 L68 DAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
G7 L68 DAAAAAAAAAAAAAAAAAAAAAAMHCiA3Tl9xg42XoqOlp6CZkoZ5bFpINSQTAQEAAAAAAAAA
G7 L68 DAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABAhMkNUda
G7 L28 DbHmGkpmgp6WjopiNg3FfTjchCwcD
G7 $0 L68 DBQoQMVN1kKvG1eT09vn78efcybajiGxQNx0DAgEAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
G7 L68 DAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAQIDHTdRbIikt8rd5/H8+fb05NXGq5B2
G7 L56 DUzEQCgUAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA=
G7 $1 L68 DAQMFFCQ0MzEwIBAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACRIcMERYcImitMbY4u33+fv8
G7 L68 D9u/o287Br5yKdV9KOSkYEAgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
G7 L68 DAAAAAAAAAAAACBAYKTpKX3SJnK/Bztvn7vX8+/n37ePYxrSiiXFYRDAcEgkAAAAAAAAA
G7 L36 DAAAAAAAAAAAAAAAAAAAAECAwMjM0JRUFAwE=
G7 $0 L68 DAwcMK0tqZ2ViQSAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAEiU5W3+iscHQ2eLr8fb7/P39
G7 L68 D+vbz7ebg183EtKOTc1IyIRAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
G7 L68 DAAAAAAAAAAAAECExUnOTo7TEzdfg5u3z9/r9/fz79vDr4tnQwbGif1s5JRIAAAAAAAAA
G7 L36 DAAAAAAAAAAAAAAAAAAAAIUJiZGdqSioLBwM=
G7 $1 L68 DBQsRP2+gnJiUYzIBAAAAAAAAAAAAAAAAAAAAAAAAAAAAHDlWh7rt8vj/////////////
G7 L68 D////////////8+fcrHtLMhkAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
G7 L68 DAAAAAAAAAAAAGDJLe6zb6PP+////////////////////////+PLsuodWORwAAAAAAAAA
G7 L36 DAAAAAAAAAAAAAAAAAAAAMWOTmJyfcUESCwUA
