Has anyone had issues with stripping the gears on the 1/10 F1 car? The motor I am using has been tearing apart the gears. I just purchased a carbon fiber axle and gears to prevent this from happening. Just curious if anyone has a solution to this other than limiting the power.
If you bought the carbon axle and gears then you won’t have to limit your power.
my motor was too powerful and I kept breaking axles. However my gears meshed well and they did not eat themselves up. How is your alignment on the printed gears?
Which material did you use anyway?
@Klaus_Daume
Hatchbox PLA
PLA is very hard though brittle. You may try nylon or hardened ABS (acetone vapor treated) instead. Propably PET+ Does a good job aswell.
@brett_turnage
You where breaking plastic axles or the carbon fiber kind?
