Has anyone modified the enclosure to fit larger materials on the cutting bed?
You mean have a larger cutting bed? I’m working on that but if you ask about fitting bigger parts only the removing the side separator and the back metal smoke outlet helps
I’d like to engrave parts that are 22" long. I’m thinking of removing the left side panel and lengthening the case to fit the larger piece, engraving half of the piece, then turn the piece around and engrave the other half… I haven’t seen a clear photo of the inside, so I’m not sure if this will interfere with the travel of the laser head
You could always cut a slot in the front to allow for long pieces to be engraved, albeit not all at once.
