Has anyone played with pressure advance in the newer versions of slic3r?
Has anyone played with pressure advance in the newer versions of slic3r? I can’t make heads or tails of the correct values to use in it if I want to turn it on…
In the help dialog it says to use a value between 0 and 10, and other places I’ve found say to use a value between 0 and 1. I’m also not really clear on what the magnitude of change is for different values.
I am using a hexagon hotend, a .4 nozzle a Bowden extruder, and 1.75 filament.
