Has anyone successfully taken something from Google Sketchup into flat file to get laser
Has anyone successfully taken something from Google Sketchup into flat file to get laser cut? I’ve got a design in sketch up that im wanting to laser cut.
There is some addons for sketchup, like “flattery” to make a 3D model into flat pieces.
Then export it as DXF and into Corel or whatever software you are using.
+Peter van der Walt exactly that plugin I use too. Works awesome. Sketchup default export is not good.
I’ve tried using this plugin and it adds in random lines - any ideas? The face I’m trying to export to STL is https://drive.google.com/file/d/0Bx6BqUBR4VS9SHFwZ2ttSG0zLUk/view?usp=sharing
in fact ignore me, if i had followed what you said and did polyline dxf and it works :stuck_out_tongue:
