Has anyone used the WS2811/WS2812 12V light strips?
I have only used the 5V strips to date, but for in-car use, 12V makes much more sense - currently I use a DC:DC converter to go from LeadAcid/3SLipo to Android/LED, but I can dump that and make my circuit much more simple with a 12V LED strip. Drawing 12V from a key-switched source in the car would make things much more simple and my Bluetooth would just come straight off the VCC power anyway.
Heat tends not to be an issue when you are flying around with 4 or 6 big electric fans holding you off the ground But something to think about with car installations in mind - and our already-hot equatorial environment.
I’ve done several projects with 12v WS2811 “pixel node strings”, but none with strips. I have used 12v strips with other controller chips, TM1809 I think.
I really like the 12v setup: you can make much longer runs between power injection points and still have everything work.
And of course there is the whole big “12v battery” universe which makes it all pretty convenient if you’re in that world already.
From looking at the pixel node strings, it looks like each node has a tiny 5v power regulator in it, which means that pixels on a “12v” string will work well down into lower voltages, too, i.e. 7v. I suspect this is part of why the 12v long pixel strings work better than long 5v strings: the voltage at the far end can drop pretty low before the LEDs actually feel anything.
Relatedly, it’s worth noting that 5v pixel strings only come up to 50 pixels, while 12v strings typically come up to 100 pixels long. Again, I think it’s all about voltage drop.
