Have some wire pr0n. Under the hood of the #AX-02 Delta. I still need to print covers for the SSRs (1 is the bed , the other is mains switching via M80/M81) but apart from that It’s pretty much done.
It’s now also running the NSTT Geared extruder (NSTT Extruder by Paciente8159 - Thingiverse), think printed E3D Titan with a MK8 drive gear. It’s making me think I should add a Titan to it.
I’ve been wanting to make my own Titan for a while. I could get the small stuff SLA’d if you think that would help. I also have 0.25mm nozzles. Thoughts?
Ah I missed that, it’ll be why when I asked for a STEP file he linked me to a conversion to solid from STL guide.
Feedback would be that he doesn’t know what a print tolerance is, when I printed the parts on the FB2020, it was all out of whack being too tight apart from the gears.
Just re-printed the NSTT body as it had a small crack, which was causing some lumpyness in the gears. The other main issue I had was the filament guide being way too tight until I took a drill snd sandpaper to it. But it’s all pretty much sorted now.
Won’t be able to say properly until I have the Delta properly running and in the farm full time. The board is waiting to be replaced as it locks up and gets worse over time until I have to pull the SD card, remove everything on it and refresh the config.
