Haven’t been using manga screen for a while. I hooked it up yesterday after hitting the update button in octoprint which it says it is updating toggle to latest. So I assume I have the latest toggle version. But the screen is not responsive it lags quite a bit. i did ass the api key to local config. Is it just my manga screen? Or is anyone else silky smooth when navigating with finger?
Hi Step,
Here is my working Manga Screen:
My only problem is the very low feedrate for X and Y. Except this I think it works very fine.
Is it a very complex model? Try a calibration cube and see how that goes?
Ok that looks good. Mine has the box empty with no model and the temp and navigation button can’t be pressed. I kept tapping them and it just not responsive. I have 2 manga screen and swapping them give the same issue. So this might be related to setup? Something not correctly install in the software?
Perhaps this is due to problems in the installation @Elias_Bakken You mean my FEEDRATE? It happens at idle runs beyond printing. Printing works ok.
If you can move the object, you should be able to switch to temp and jog as well. It’s not always super responsive, so you might have to try a few times. @Daniel_Kusz , the feed rate is set in OctoPrint, is it not? If not I think it must be hard coded
Here’s mine
Ah, Step I see that you have a white line in the side there. That means either a faulty HDMI cable or a faulty EEPROM chip on the screen. Instead of getting 800x480 resolution you are getting a 640x480, which probably also throws the touch screen off… you could try to force a resolution and see if that helps. Google Beaglebone Black Custom HDMI resolution.
