Having issues all of a sudden with skipped steps on rasters running LW3 on @raykholo 's Cohesion 3D. I’ve tightened the Gantry belt as mentioned in @Alex_Krause 's post, but I’m still having the issue. It’s sort of unpredictable.
Originally shared by Alex Krause
Started noticing a bunch of shifting in my images… I thought I was missing steps at first… so I checked my X axis belt tension on my k40 and felt a ton of slack in the belt. So I jogged the head to where the hole that leads to the electronics pannel is and tightened both screws that I circled in the second image a 1/4 turn at a time until the belt was where it should be… fingers crossed that this fixes my problem and remember don’t over tighten the belt
I also have a feeling I’m just doing the engraving wrong…most of what i do is cutting. It’s not as smooth or fast a I’ve seen some people do when they engrave.
The reason I ask is that the 24v supplied by the laser PSU is only rated at 1amp max @donkjr confirmed this… I also noticed I had more skipping issues with the coiled hose from my air assist attached while going at high speed and acceleration settings
I’ve had this problem since I switched to a cohesion board on anything I try to engrave larger than 2 or 3 inches. I’ve tried everything short of changing my stepper motors
Try slowing down your engrave speed a bit @tyler_hallberg I saw more problems at 400mm/sec than I did after changing my max speed to around 300mm/sec by doing so you need to back off the power at which you engrave to compensate for moving slower
We have tried everything. I see no speed change when going from 100mm/s to 400mm/s. I have changed out the controller parts, re did the configure file, update firmware, and nothing helps. Doing smaller things is fine, but it almost gets lost when doing larger engravings.
I am using LW4. If I turn off join pixels machine runs like garbage. If I leave it on it runs but not the speed i set it at. I just upgraded the firmware again to see if anything has changed. will update shortly
Speed & inertia: do you increase the head weight ? (cable chain, air assist) could be related with max current available for the motor
saying that, i just notice you have only one break in your image so just one (large) skipping. hard to think it could be a software setting.
maybe just an acceleration issue (not computed) before changing direction. sorry just a shout in the dark !!!
