Having some trouble milling with the Z axis of the Eleksmaker. A circle is no problem but when I try to cut for example a square it doesnt even start. I am using a SVG file and a circle is of course not segmented. A square is and from what I can understand it seems that it hangs on those segments. Who knows how to fix this. So connect segments in a SVG file or maybe a setting in LaserWeb so it will work.
Make sure you import always connected lines aka paths. ![]()
