Having trouble with saving a job. So does saving Workspace save everything, meaning Gcode/Image/etc? Cuz i want to be able to save everything then just be able to reload it when needed. I do save workspace but they never load anything up.
yes save workspace will save your documents and operations, all you will need to do is generate then run. Make sure when you save that the file tag is .json sometimes it deletes that part and doesn’t work then.
@Domm434 Thanks!
