Hehe getting fancy with LED. Turns out the openbuild 2020 extrusion has a nook that is good not only for hiding gt2 belt but also LED strip
Cool idea…
Just don’t short the led solder points against the extruded aluminum!
hi, sorry is this a somehow moderated group. I have posted a question and it seems hidden somehow.
Did you connected leds to psu or fan pins? I have my strips connected to fan 3 with custom dimmer in Octoprint
But I need to turn it up manually.
I used this before. I put some polypropilene transparent notebook cover, in strips to avoid contact with the frame. Works beautifully
It’s actually very manual right now. It’s a USB led strip from amazon
Looks like a nice cooling solution. Are you happy with it? Can you link to the fans model?
Here you go. Take 1 week to arrive in California. Very happy with both seller and the product. The air flow stream is very focused so you have to point to it as close as possible. https://www.aliexpress.com/item/5V-0-14A-UDQFNKH01-3507-blower-3CM-mini-notebook-cooling-fan/32682508049.html?spm=2114.01010208.3.10.6eKSn4&ws_ab_test=searchweb0_0,searchweb201602_2_10065_10068_10000009_10084_10083_10080_10082_10081_10110_10111_10112_10060_10113_10062_10114_10056_10055_10037_10054_10033_10059_10032_10099_10078_10079_10077_10000012_10103_10073_10102_10000015_10096_10000018_10052_10053_10107_10050_10106_10051-10110_10033_10037_10077,searchweb201603_2,afswitch_5,single_sort_2_default&btsid=634d47ac-9b08-49a3-b4a6-22d7552cfbab
thanks, overall you have an interesting extruder, what is that thumb nut for ? adjusting the fans ??
A question about the fans. How well do they manage PWM? Whats the lowest percentage they run smoothly?
I just used my hands to feel the air movement anything below S200 I couldn’t feel it. This pic below is at S200 I think it’s good enough but you need two of them
@Shachar_Gafni I use E3D titan for my extruder. I assumed you meant my hotend setup
the two thumb nuts are there to adjust the two FSR sensor sensitivity. It’s my z endstop
E3D ? In bowden i guess. it does not look as E3D V6 hotend, what is it ?
The hotend is from @Shai_Schechter ​ deltaprintr mini hotend
