Hello again,
I’m still struggling with obtaining smooth movement from the laser head on my CNC. This is not a mechanical problem. It is due to the planner/data transfer rates or browser not keeping up with the CNC machine.
I’ve tried changing the number of lines uploaded, and the delay time to send the data, but I just cannot get the settings right to get a continuous smooth movement of the laser head from start to finish.
If I upload too many lines, the browser stalls and becomes unresponsive until the uploading is finished. The laser head stalls during this time, but then it becomes a little smoother after the upload completes, but by then the damage has already been done. This means I have to complete uploading the data by the time the laser head reaches its first cut. This limits me to around 1000 lines maximum (unless I slow the head movement right down until it reaches the first cut). This does not seem to be the right solution though…
I have downloaded JSON 1.95 Serial Server, but this has not helped solve the problem.
The really strange thing is that everything was working perfectly well a few days ago. I repeated the same cut on several occasions (just played the same G-Code around 15 times - each cut takes around 20 mins). The first few cuts were near perfect, but towards the end, the movement was so bad that the laser just blew through the material all over the place instead of creating a clean smooth cut.
I have read through the instructions to understand the number of lines / multiple lines, and delay times to send the data and believe I understand whats happening here, but does anyone have any step by step checks to assist in finding the best figures for a particular set of problematic G-Code lines…
Thanks in advance…
