Hello All, Has any one enabled the filament change option using a REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER ??
I have uncommented the line as required in marlin but the option is not on my Lcd controller, any advice would be appreciated …stevep
Have you enabled FILAMENT_CHANGE_FEATURE in the advanced configuration?
Yes , done that …
The option should be if you uncommented both lines.
I’ll test it did weekend and let you know…
Ok , thank you
@stephen_prescott , I have tested this.
I’m using the RRD Full Graphic Smart Controller, as you are, and I updated the firmware with FILAMENT_CHANGE_FEATURE, and it all works.
I’m running RCBugFix (which is bug fixes on top of RC8)
Go to the Menu -> Prepare -> and towards the bottom you will find “Change Filament”.
I can upload my config and config_Adv if you like…
Hello Panayiotis, thank you for your help with this, yes I would like you to upload your files
Regards…stevep
@stephen_prescott
Here you go:
Configuraiton.h:
http://pastebin.com/sV2cpcrB
Configuraiton_Adv.h
http://pastebin.com/DGvdErLG
Thank you for this Panayiotis, I will set it up later
Regards and Thanks …stevep
