I don’t know if anyone can help but I have the similar issue, and neither of those branches seem to compile on my 3.6
First linked branch (GitHub - kcouck/FastLED: The main FastLED library (successor to FastSPI_LED). Please direct questions/requests for advice to the g+ community - http://fastled.io/+ - we'd like to keep issues to just tracking bugs/enhancements/tasks.) gives:
In file included from C:\Users\Paul Whitrow\Documents\Arduino\teensy_saber\teensy_saber.ino:11:0:
C:\Users\Paul Whitrow\Documents\Arduino\libraries\FastLED/FastLED.h:558:2: warning: #warning “No pin/port mappings found, pin access will be slightly slower. See fastpin.h for info.” [-Wcpp]
C:\Users\Paul Whitrow\Documents\Arduino\libraries\FastLED/FastLED.h:17:21: note: #pragma message: FastLED version 3.001.005
pragma message “FastLED version 3.001.005”
In file included from C:\Users\Paul Whitrow\Documents\Arduino\libraries\FastLED/FastLED.h:65:0,
C:\Users\Paul Whitrow\Documents\Arduino\libraries\FastLED/fastspi.h:110:23: note: #pragma message: No hardware SPI pins defined. All SPI access will default to bitbanged output
pragma message “No hardware SPI pins defined. All SPI access will default to bitbanged output”
In file included from C:\Users\Paul Whitrow\Documents\Arduino\libraries\FastLED/FastLED.h:48:0,
C:\Users\Paul Whitrow\Documents\Arduino\libraries\FastLED/fastpin.h: In instantiation of ‘class FastPin<64u>’:
C:\Users\Paul Whitrow\Documents\Arduino\libraries\FastLED/platforms/avr/clockless_trinket.h:96:49: required from ‘class ClocklessController<64u, 45, 113, 68, (EOrder)10u, 0, false, 10>’
C:\Users\Paul Whitrow\Documents\Arduino\libraries\FastLED/chipsets.h:468:7: required from ‘class WS2812Controller800Khz<64u, (EOrder)10u>’
C:\Users\Paul Whitrow\Documents\Arduino\libraries\FastLED/FastLED.h:102:52: required from ‘class WS2812B<64u, (EOrder)10u>’
C:\Users\Paul Whitrow\Documents\Arduino\libraries\FastLED/FastLED.h:294:39: required from ‘static CLEDController& CFastLED::addLeds(CRGB*, int, int) [with CHIPSET = WS2812B; unsigned char DATA_PIN = 64u; EOrder RGB_ORDER = (EOrder)10u]’
C:\Users\Paul Whitrow\Documents\Arduino\teensy_saber\teensy_saber.ino:105:69: required from here
C:\Users\Paul Whitrow\Documents\Arduino\libraries\FastLED/fastpin.h:206:2: error: static assertion failed: Invalid pin specified
static_assert(validpin(), “Invalid pin specified”);
Using setup code: FastLED.addLeds<WS2812B, LED_DATA_PIN, COLOR_ORDER>(leds, NUM_LEDS)
Second linked branch (https://github.com/kcouck/FastLED/tree/Teensy_3.6) gives:
C:\Users\Paul Whitrow\Documents\Arduino\libraries\FastLED/platforms/arm/k66/clockless_arm_k66.h:14:49: required from ‘class ClocklessController<64, 45, 113, 68, (EOrder)66u, 0, false, 50>’
C:\Users\Paul Whitrow\Documents\Arduino\libraries\FastLED/chipsets.h:468:7: required from ‘class WS2812Controller800Khz<64u, (EOrder)66u>’
C:\Users\Paul Whitrow\Documents\Arduino\libraries\FastLED/FastLED.h:90:34: required from ‘class NEOPIXEL<64u>’
C:\Users\Paul Whitrow\Documents\Arduino\libraries\FastLED/FastLED.h:306:28: required from ‘static CLEDController& CFastLED::addLeds(CRGB*, int, int) [with CHIPSET = NEOPIXEL; unsigned char DATA_PIN = 64u]’
C:\Users\Paul Whitrow\Documents\Arduino\teensy_saber\teensy_saber.ino:106:57: required from here
Using setup code:
FastLED.addLeds<WS2812B, LED_DATA_PIN>(leds, NUM_LEDS);
I’m at a loss and need help … PLEASE!!
