Hello, all ok finally I made possible to test first job...
Hello,
all ok finally I made possible to test first job… now I have another problem with the size…
I’m using a a5 laser engraver… first test came too big even if all is set ok. After I had a suggestion: type $$ and change $100 and $101 both from 250 to 80
Now I get an image with wrong proportions… I try to do a test of a square and I get a rectangule, all images are “pressed” when engraved.
Screen shows it ok.
what’s wrong?
thank you
Is this an SVG?
@Ariel_Yahni_UniKpty png
Post an image of said distortion
https://profiles.google.com/photos/100075568232518942576/albums/6475641615228526273/6475641616873809586
https://profiles.google.com/photos/100075568232518942576/albums/6475641725866497185/6475641727142466146
Type $$ in the console and post the complete result
$0=10
$1=25
$2=0
$3=0
$4=0
$5=0
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=0
$21=0
$22=0
$23=0
$24=25.000
$25=500.000
$26=250
$27=1.000
$30=1000
$31=0
$32=0
$100=80.000
$101=80.000
$102=250.000
$110=500.000
$111=500.000
$112=500.000
$120=10.000
$121=10.000
$122=10.000
$130=200.000
$131=200.000
$132=200.000
I will assume that the distortion is on the Y axis per the image. You need to confirm that the correct value for $101=80. So do the following.
Place a mark in the current location of the Y axis plates then jog 100mm in the Y axis and measure the distance traveled. If it’s not 100mm then you need to calibrate that
@Ariel_Yahni_UniKpty original value for both 101 and 100 was 250… .do I put again it to 250?
No, do the procedure I said above. Yo can do it for both axis and make anotación for the distance
@Ariel_Yahni_UniKpty I’ve done it for both X and Y axis… it is ok
Really strange , can you post a screenshot of the LW operation generated ( the whole screen )
@Ariel_Yahni_UniKpty draw in the screen is perfect!!
If you can post the screenshot with the generated gcode
