Hello all, question: We d a lot of square-ish parts. Our original issue was sticking to the bed, but the real issue is pulled up corners. If I plan to plot a 3x3x1/4" tall block, the corners of the 3x3 block will pull up so I get a very very shallow dome on what should be a flat surface.
Even worse is if we try to make a box… a 3x4x1" tall box, the bottom won’t be flat. We try to model prototype some sheet metal designs, and this is causing a bit of greif.
We’ve recently been trying no heat on the bed, and a piece of plexi in place of the glass. While it is much better, it still has a slight dome-ness… My theory is that he heated material is contracting as it cools, therefore contracting the part as you build…
Ideas? thoughts? suggestions for a better, flatter part?
Makergear 2, PLA, 185°C nozzle, no cooling (fan), simplify3D…
