Hello all! We wanted to share some of the work that we've been doing
Hello all! We wanted to share some of the work that we’ve been doing and hopefully add back to this amazing library. We’re using some code based on the NoisePlusPalette animations to animate the weather inside this infinity cube.
Here is the code - http://pastebin.com/pVYByhAa
The code is a little sloppy, so I apologize in advance… but here is what I’m trying to demonstrate in it -
  1. We set up code for the animations to take triggers from the motion control rig. It runs normally until the first trigger, then advances frame-by-frame. When it’s just running, you can set it to run the target framerate for your motion control video so you can see the speed it will end up looking like.
  2. You can remix the palettes with SetupWeatherPalette() to reflect time-of-day and cloudiness and assign colors to the sky and clouds.
  3. A side note - we also added palettes based on color theory. So now there are analogous, complementary, split-complementary, triadic, and double-complementary animations. These make some very pretty color combinations.
We’ve got more shots like this in our Kickstarter video too, which you can check out here - http://kck.st/1OvjXui
http://www.youtube.com/watch?v=r4YRGjL_m_M
This is really cool! Tiny universe.
