Went 0 for 6 today trying a 3D carve, about halfway thru the program it loses track of position and things get weird
2x it happened in the same spot and I opened up the junction deviation to 0.010 from 0.002"…Thought I had it but it will not complete the 2MB G-Code successfully.
Can anyone who has root caused this behavior before please provide some avenues to debug - I am a CNC noob
First guess is your stepper drivers overheat and shutdown on and off and you lose steps. Or your pulleys are loose and steps are lost. Does the Gcode stop executing? I’m guessing Gcode keeps running fine you just lose position on spindle head which is steppers shutting down.
I’ll inspect stepper drive temp during my next run on Wednesday. Didn’t seem too warm but maybe there are some maneuvers that produce heat quickly. My current trim is set on the lower half of the adjustment range
The Gcode keeps running but the machine becomes lost.
I’m also going to break down my Gcode into steps and try that, if nothing else I’ll be able to pinpoint the path deviation a little easier…hopefully
I just had this happen again, it seems like Gcode from Easel is fine but from Fusion360 is not fine…about halfway thru the job it just wants to draw a circle
Happened twice (at the same spot) with different current trim and microstep settings.
I’ll dig around Fusion forums and see if there’s related material
