Hello Can I ask questions ?! how can i make more choices about Make
Hello
how can i make more choices about Make like " laser cut , raster , and another ?!
to make laser cut must file be SVG ?!
if that when i import file svg the program is freezing why that My lap is :
processor :i5
ram : 6 g
Your svg is probably too heavy or faulty to be loaded by lw
You can load Dxf too.
Look for laserweb on YouTube for videotuorials of use, and read the docs (check the info of this group)
@Jorge_Robles
thanks for replay … how can i make svg is too smal so i can us it in lw … and photo .png …ect can be use laser cut on it or not only svg ?!
Yes, you can use JPG and PNG also to do raster engraving. Once the SVG is loaded you can select the documents in the left pane and use the transform bar on right canvas to resize to your need.
Again, please read documentation of use or check the videotutorials.
