Hello community, I share an idea to replace a rotary mechanical switch, of course,
Hello community,
of course, using FastLED :slight_smile:
https://www.youtube.com/watch?v=zYJo0EiSCpY
Excellent! Mind if I ask where you got the spinner? The only ones I’ve found are around expensive.
@Jason_Coon https://www.ultimarc.com/SpinTrak.html
I really like it! How many pulses per revolution does that encoder output? I was wondering how hard it might be to get the pixel position/rotation synced with the knob rotation.
@Jason_Coon A rotary encoder with no detentes should spin fairly well if you put a large heavy knob on it, particularly if you put the weight to the outside as if it were a lead filled tire.
@marmil 1200 pulses per revolution, more than enough to synchronize, but you need a reference; a sensor to know the starting position or use an absolute encoder.
