Hello everybody!, has my GRBL auto level never worked, I decided to buy an ARDUINO DUE. I programmed it with Tiny G2 firmware using the Chilipeppr tool.
This works OK, so I had to download the driver. but Now, I need a tutorial to config the parameters of my Shapeoko 2, Anybody knows? thanks
Do you know your config parameters for the machine, like the steps per mm for each axis? You can pull these off your grbl device if it’s been moving the machine properly. Then you should set up the new parameters as a startup script in the Tinyg workspace. Make sure you set ‘send no intit’ or something like that from the Tinyg widget pull down menu as well.
