Hello everybody! I was planning to install a HPB on my Replicator 2,
Hello everybody!
I was planning to install a HPB on my Replicator 2, but first, I will need to replace the power supply.
I was wondering if it were possible to use a PC power supply (with a little work) instead of a dedicated one.
Is the one you can see in the link sufficient? If my NOOB physic level is right, I only need a 120W power supply in order to have a 12V - 10A output.
Thanks a lot.
http://www.steg-electronics.ch/fr/article/lc-power-lc420h-12xxx-145102.aspx
http://www.easyreprap.com/?deeplink_referrer=socialB_google#!product/prd1/2005009735/30amp-12vdc-power-supply
I know I may use that power supply. Because I should buy it outside Switzeŕland, it will cost much more money (shipping + taxes) than a simple PC power supply I could buy at a local retailer.
I use a pc power supply without issues.
@Jason_MeGahee Thanks a lot for this answer. So I can understand, with your answer that the circuit is a serial and the amperage is the same on every wire.
Now, I will have to know which wire has 12V… :wink:
If you dont want to mess with the modifications, you could just get a 12V directly from your PC to your 3D Printer (if you have some decent psu). You can even add a switch.
yellow wires are 12V, red one are 5V
be careful, there may be multiple “rails” that the 12 v lines run on. often nicer power supplys have 2 or more rails and both receive only a portion of the amps
also you need more than 120W to get 10A at 12V out. PSU’s are generally only about 80% effecient. If it will even give you 10A, pushing past the 80% is a good way to trigger and overload shutdown.
Both of my printers use ATX supplies. One has a 400, and the other uses a 650 that came out when I upgraded my PC. the 650 is almost insufficent to power a 300mm heated bed.
also, please read this:
http://reprap.org/wiki/ATX
I agree with Chapman, bigger is better. Especially if you are going for a heated bed, which really you should. My 400 watt power supply is kind of weak. But still, it’s easy enough to hook up.
Bigger is not always better. But try to aim at 50-70% max of the capacity. If you need 70watts, try to get a 100watts of continuous power (not peak) minimum.
Thanks a lot for all these answers… It helps a lot!
@Chapman_Baetzel Thanks for the link, I think I’ll have some more answers there.
@Sebastien_Plante How will I know the continuous power of a power supply?
Check the side of the power supply or on the retail box. That info is provided by the manufacturer.
sometimes, cheap psu only have the “max” (peak) written. In this case, I assume continuous (RMS) is 50% of max.
Thanks a lot! Lots of info
Now, I’ll have to power my replicator 2 with the new power supply. Not so relaxed! :wink:
Take a look at this : http://www.wikihow.com/Convert-a-Computer-ATX-Power-Supply-to-a-Lab-Power-Supply
My lab PSU is based on that. I use it to power my Delta until I find a nice place to setup the PSU :slight_smile:
@Sebastien_Plante Thanks a lot… or should I say: Merci beaucoup?
Je parle effectivement français (langue native) du Quebec!
You must connect the green and black wire only
Its not that simple. Especially if the PSU have a load test, it will shutdown by itself.
You can start a PSU like that, but not use it stable
