Hello everyone, I am new to this forum and need some help.
I have a blue/white K40 with the digital percent control panel. I am soon replacing the controller with a Cohesion3D controller. Does anyone have any suggestions for a replacement laser power supply? The problem I’m currently experiencing is that the digital control does not behave well. When I use the buttons to increase or decrease the power, the change does not always follow the buttons. For example, I change the percent by 1 - the decimal number changes rather than the unit. When I change the 10’s number, either the unit or decimal number changes. It is annoying. Is this a problem with the digital controller, the power supply or both?
I’ve read in some posts that it is wise to have a separate power supply for the motors and a dedicated laser supply. Can someone point me to wiring diagrams provide recommended power supplies for use with the Cohesion3D board?
Other’s can help with the power supply question, but I can tell you the problem with your digital current controller isn’t uncommon and isn’t related to PSUs as far as I know.
If your digital display board is like mine it is connected to the K+/K- connector for measuring output current and to the Gnd/In/5V connector for setting the output current (via PWM). The button to the right of the display seems to switch between the two purposes.
If the PWM signal is not playing nice with your Cohesion3D board you can replace the PWM signal with a 5k potentiometer. Keep the Gnd and +5 connected to the digital board (so you can still use it to measure current) and also connect them to the ends of the 5k pot. The wiper of the pot replaces the PWM signal and connects to ‘In’ in its place. The 0V to 5V analog signal form the pot sets the output current.
The digital display board DOES NOT measure current, it displays a number which is the percentage of the max power. ie. 20 means 20% power not 20mA A lot of people are confused over this.
My buttons act weird as well when I try to single step (push once) somestimes the 1.0 button will do a .1 increment, etc… but if I hold it down it doesnt seem to do that, annoying but not a big deal…
Ok, I’ve decided to dump the digital percentage panel for a pot. I’ve searched but can’t seem to hit the right keywords. I have a current meter installed already - but not completely sure I’ve wired it correctly. Now I just need to find the part and wiring info to proceed. links?
