Hello everyone,
I have been lurking for a long time now but I now need your help.
So I have a K40 machine with a Smoothieboard mod (K40 middleman board + logic level converter), it has been working well for almost six months, cutting through 5mm plywood at 2.7mm/s 80%, but now I can’t cut through it even at 100% and 1mm/s…
I’ve checked the mirror and they are perfectly aligned, I’ve cleaned them too, with no luck.
Laser is working but I don’t have a power probe so I can’t check the real power.
I have tried a calibration pattern (cutting squares at speed from 1mm/s to 10mm/s and power from 10% to 100%) but none cut through the wood.
What can I do to find the problem ?
Thank you
