Hello everyone I'm new to the community just received my Model 40W 300x200mm CO2
Hello everyone I’m new to the community just received my Model 40W 300x200mm CO2 laser and have got some questions I want to make some Christmas ornaments this year using plexiglass and was wondering how thick can I expect to cut what settings for power and speed should I use I could figure this out on my own but not before Christmas so any help would be appreciated
I’ve read of people cutting 4mm at 10mm/s on 60% power, i’ve not done enough cutting yet to give advice.
Some Google results :
https://www.google.co.uk/search?site=&source=hp&q=k40+laser+cutter+acrylic+speed+power&oq=k40+laser+cutter+acrylic+speed+power&gs_l=hp.3...2762889.2768935.0.2769085.38.31.0.6.6.0.166.2290.28j3.31.0…0…1c.1.64.hp…14.24.1254.0.wBwVMdAk-Mg
Make yourself a test file and cut it in scrap using different settings until you get acceptable results. A good starting point is to start at 25% power at 10mm/s and increase it by 5% power up to a maximum of 60% power. If this does not cut through the material for you, then slow the speed down by 1/mm/s until you get a through cut. The lower the power setting you can get by with, the better, it will increase the life of your tube. I personally do not exceed 70% power ever, if need be I will run multiple passes to achieve the cut.
