Hello everyone, sorry for my English I am translating with google ...
Hello everyone, sorry for my English I am translating with google …
I know very little electronics and ask for help to those in the know definitely more than me.
I have a CNC controlled with Arduino + grbl and would like to add the laser module but do not know how to do the wiring.
I would buy this laser: http://www.makeblock.cc/laser-engraver-upgrade-pack-500mw-for-xy-plotter-robot-kit-v2-0/
but do not know how to connect it to Arduino.
I think we need a transistor but do not want to burn everything.
Can you give me some indication about
maybe a wiring diagram would be helpful.
thanks to all
hello
Hi, check this:
http://learn.makeblock.cc/laserxy2/
i think you have to buy their arduino board BaseBoard Me 1.0 - http://www.makeblock.es/productos/me_baseboard/
hello thanks for reply!
I would not even buy the card BaseBoard Me …
I wish I could operate the laser directly with Arduino using commands GCode M3 and M5.
do you think is possible?
I hope I explained myself.
hello
Bon giorno, pudes escribir in it te comprendo ::slight_smile:
cerca il ditribuidor it .: https://www.futurashop.it/index.php?route=product/search&filter_name=makeblock
ok thanks so much
there is a post in instructables:
and he uses an Arduino controlled laser. Sourcing out of eBay is cheaper that the full kit
Look for the electronic circuit diagram, it says everything you need.
I know in other boards (ie. TinyG) you wire the laser input to the spindle on/off, and the GCode is used like in a router; I think the difference is the laser must be pulsating instead of continuous ON; but you can do the same with grbl
I picked up a similar kit a while ago, which installs into a 3d printer to replace the extruder, but the laser was so low power that it can’t cut anything more than paper. Still, it’s cool to have a laser, even a wimpy one.
thank you all for your answers, I have been very helpful…
2W laser diode with lens:
http://www.ebay.com/itm/2W-445nm-M-Type-M140-Blue-Laser-Diode-Copper-Module-W-Leads-Aixiz-Glass-Lens-/170892986250?pt=LH_DefaultDomain_0&hash=item27ca04078a
2W driver:
http://www.ebay.com/itm/New-Laser-Diode-laser-module-Driver-for-100mW-2W-445-450nm-blue-laser-TTL-/231457182297?pt=LH_DefaultDomain_0&hash=item35e3ec5259
cheaper and more powerful(4x) than the kit
oooh very well, thanks Nelson!
I recently found this great post on this subject.
Thank you james!!
See the makeblock forum for specifics such as :
http://forum.makeblock.cc/t/xy-plotter-2-0-with-laser-kit-waiting/800/2
good luck
