Hello everyone, yesterday i received my K40 machine,
Hello everyone, yesterday i received my K40 machine, honestly besides my fan came completely broken. Everything seems okay.
So i aligned all the mirrors, and cleaned them. But i am not able to cut plywood (3mm with 5mm/s 20mA), i have seen someone wrote for reference he is cutting 3mm with 10mm/s 10 mA.
What should i check?
Alignment - search for the flying wombat alignment on the web - there are many ways to align the beam - only a few work well.
That was me. There are many things to check: recheck alignment, water cooling temp, lens correct position.
and focus
Stock focal lens in k40 and clones is 50.8mm ,so aim for that ddistance to mmiddle ofwhat you are cutting
And check that the lens is installed correctly - bump side should be up. Lots of times they come installed upside down.
