Hello FASTLED lovers! Im woking with a single ledstrip but is has been cutted
Im woking with a single ledstrip but is has been cutted in thre (A from 0 to 10, B 10-20 and C 20-30) and custom mounted in a phisical different way (A C B). So I need to configure le ledstrip in A C B order. I thougt that it could be done this way but there is a problem when adding leds on the same pin:
void setup() {
FastLED.addLeds(leds, 0, 10).setCorrection( TypicalLEDStrip );//A 0-10
FastLED.addLeds(leds, 20, 30).setCorrection( TypicalLEDStrip );//C 20-30
FastLED.addLeds(leds, 10, 20).setCorrection( TypicalLEDStrip );//B 10-20
The effect is the same as:
void setup() {
FastLED.addLeds(leds, 0, 30).setCorrection( TypicalLEDStrip );//ABC 0-30
And of course it looks odd. I was confident that addLeds fuction would respect somehow the sub arrays and the order of the addition.
Even this senctence is not respecting the initial offset of 20 leds.
I hope I just coded that wrong!
I don´t understand the precise question, but shouldn´t it be 0-9, 20-29 and 10-19?
Use 3 differnt pins instead or one pin and connect the end of one strip to the beginning of the next one.
I would use one pin and write a little mapping function that sorts the things out in the way I need it.
The order is just as you mentioned. The wiring cannot be changed, it has been encapsulated an the other pins are compromised. About the mapping function… Thats what i was trying with the addLeds calls…
So it is basically about the mapping? What about something like
uint16_t XY( uint8_t x, uint8_t y) {
uint16_t i;
if( x == 0) i = y; //A
if( x == 1) i = y+20; //C
if( x == 2) i = y+10; //B
return i;
x names the strip, y the position
Thanks Stefan very much!!
The goal is to do that in a way that I can access the strip via just one array, like in this example:
Just with one difference, each strip beeing phisically substrips of the same strip.
This way I can program regardless of the phisical structure underneath.
I think It could be really powerfull!
With my code you have all the leds in one array…
Please try to say in one clear sentence what your goal is. I probably didn´t get it yet.
Just one parameter “i” to go all trough the final strip.
Like in this example:
Ok, so set up one strip:
FastLED.addLeds(leds, NUM_LEDS).setCorrection( TypicalLEDStrip );
Add this function to your code and call SortMyLeds(); before every FastLED.show();
It will swap part B and C:
void SortMyLeds() {
for (byte i=20; i < 30; i++) {
CRGB buffer = leds[i];
leds[i] = leds[i-10];
leds[i-10] = buffer;
Thanks for the code! I wanted to achieve this in the setup(); via multiple addLeds calls but your code works like a charm!
Thanks @Stefan_Petrick !
Glad I could help out.
