Hello fellow Chilipeppr enthusiasts! I was hoping someone could point me in the right direction. I’ve been using jscut to generate gcode, and have noticed it’s difficult to pair a hole cutting operation with an outline cutting operation because you cannot have separate cut styles (inside vs. outside) for different sections of the job (as far as I can tell). I typically just create a number of separate gcode files. Is there a way to chain two or more gcode files together so I don’t have to individually load each file? I often have multiple gcode files that need to run back-to-back with the same bit, so it would streamline things quite a bit if I could do this. Thanks! Also, is there another free CAM program anyone prefers that might allow me to create separate tasks for each component in the Inkscape SVG files that I’m unaware of?
i use fusion 360 now cuz it is free.
Perfect, I’ll check it out! Thanks John.
“Introduction to Fusion 360”
